I don't think a few mm difference would matter since there's a clamp on that end.
Yes I was planning on just swapping the pipe and keeping the wagon airbox. I found an EX sedan at the junkyard and I was going to try swapping the intake pipe, but wouldn't you know, all the DA intake pipes were gone!
I was going for the OEM look. It's not a big deal, but I thought that while I'm spending so much time at the junkyards lately, if there was a bigger diameter intake pipe I could just throw on there, I might as well go for it.
For starters, the d16a6 has a smaller throttle body inlet. that could be a problem.
You can pick up some rubber hoses (for plumbing and such) from Home Depot (or similar) for cheap and make it work.
