Help! Charcoal canister bypass
So I made a couple posts about my Wagon having a gas leak after a while on the interstate. Turns out the gas was coming from the air vent pipe on the bottom of my charc canister. Rather than paying the 186 f-ing bucks to replace the can, I want to bypass it. Is that as simple as pulling the hoses off it and blocking them off? Will that fill my engine bay with tons of nasty gas fumes? Will that affect the performance of my car? If everything would work with it off does anyone know the best way to do it? Any help appreciated.
I don't know if a worn out charcoal canister could cause actual fuel to leak out of the vent tube.... is it just a few little drips, or a lot of gas? If it is a lot of gas, it seems that somehow there is liquid making it's way through the vent line. This could maybe happen if you severely overfill your tank? I would check out the evap solenoid on the firewall next to the map sensor. I believe with the car warmed up, and with the ignition in the "ON" position (with the car NOT running) you should be able to feel the solenoid click on and off when you remove/replug it's electrical connector. Make sure you feel it clicking, it's a pretty obvious click.
I would definitely check the solenoid, and the two way valve in the top of the tank.
You could order one online or failing that, get one from the junkyard. I think all of them are interchangeable within the same OBD generation.
The problem with bypassing that besides needlessly killing the environment and losing 3-4 mpg (I know I know, no one cares, right?) is that you're going to have a leaky gas smell some describe as a rotten egg smell, and you could damage your fuel system. Honestly I'm not too sure about that. But the purpose of the charcoal canister is to accept residual fuel pressure sitting in your lines when you turn off your car.
If you want to kill the environment, waste gas, and make less hp just to get rid of a black can in the engine bay you might as well take the car off the road and continue working on your trailer queen car show project. Plus that just makes you stoopid.
-golf clap-
I'm too much of a tree hugger to have touched this thread... thanks for that.
$186 lol
