Engine Building Gurus, please help.
Rebuilding my motor. Putting new piston rings in.
Heres my dilema.
The bore and stroke on my d15b7 block is 75x84.5mm. (or 3.0in. x 3.33 in.)
I microed my cylanders and this is what I got,
Ordered from (#1-Closest to crank pulley) thru (#4 closest to block stamp);
#1 - 74.96mm #2 - 74.97mm #3 - 74.95mm #4 - 74.92mm
So do I stick to buying 0.00mm rings? Or should I go bigger? This is my first rebuild and pistons and rings are entirely new to me.
Any help is appreciated. Thank you!
Heres my dilema.
