Tire rub?
so i put on some integra snowflakes/starfish rims on my 91 wagon
but for some reason on the passenger front wheel the tire rubs bad
and its eating the inner tire
have any of you guys had the same problem?
and how many f you have hx's on thier cars? i am wantin to get some cuz of the tire rub
  • Are you running coil overs? Has the car been in an accident? Is something bent? Does if rub when your going straight or turning? Need more info to properly help you.
  • chop_sueychop_suey Band Wagon
    well the it doesnt rub until i turn left
    stock suspention
    nothing is bent at all
    and doesnt look like its been wrecked
  • theidealonetheidealone New Wagonist
    I actually just bought an 88 RT4WD. First I had my HXs on there, now I rock my Snowflakes. Neither of them rub, that I have noticed. pretty sure I would notice though.
    Although, the rest of my car is stock.
  • Are all the tires the same size? Check the fender liner and make sure its not loose.
    roll ur fenders it well help if u haven't done it yet...
  • tr4c3tr4c3 Band Wagon
    Any pics? How is the condition of your suspension?
  • hows it ride? sounds like you might have a bent tie rod or something out of whack with your front end suspension for it to be rubbing the INSIDE of the tire. normally when you're hitting the fender the outside gets chewed up...the inside tends to be either camber wear or if it's isolated to one specific wheel, something much worse with the alignment/messed up suspension components
