Window trim questions
when i got my wagon the driver side window was missing that outter rubber piece that i guess keeps it inplace? so my window is off track bad and rattles. i was wondering if the same trim from a 4 door ef would work or is it specific to the wagons only?
The wagon's roof is higher, so it has bigger/higher windows. It may work but just be a little short at the bottom...certainly better than what you have now, right?
thank you sir. there are a ton of 4 door efs at the junk yard by me so ill snatch one up
