Honda Civic 1500 Dx Wagon
So I buy this 86 Civic Wagon. When I am setting up the insurance online it looks up your vin #. So it says it's a "1986 HONDA CIVIC 1500 DX wagon". So this means I have an L4 1500 engine right? Is this a good engine? I havent had much luck getting info on the different engines and such.
It says 12 valve on the top. I may get some shop rags and WD40 and clean up the engine compartment to see what I can see. I know I probably need to replace one of the gaskets. There is a little bit of oil leaking on one part. There also is a slow tranny leak. not looking forward to sorting that out.
Is this engine worth putting time into or should I be looking for a crate engine as this car is at 84k and proabably needs a new one soon. Though it did pass smog fine so it cant be too off right?
If you really want to do the engine get a donor teg & swap over the engine &brakes...you'll have a Wagon Type R :twisted:
And yes on the brake swap, I did a rear brake swap on my CRX and it turned out amazing.
Kragen has a deal on filter and oil right now. Any heads up on the best oil? Synthetic?
When I drove a ford E150 I had NO trouble finding parts. Plenty of Ford vans and pickups to pull parts from, plenty of fords/lincolns/mercurys larger car parts carried over too.
My old datsun 210 had some engine parts in common with certain CNG powered forklifts!
Since your wagon is carbed, it makes an engine swap more of a pain. They did make carbed ZC's though for this era of Hondas. It's recommended you find a donor Teg (86-89) so you can swap everything over.
Redpepperracing.com is your best resource for information on the 84-87 Civics.
I would just drive the thing if it were me though.
After that I am gonna want to get under the hood and see if I cant get some more oomph out of it. Engine swap I only mentioned because it seems people want to do that on these at 90k or so. I have a hard time making some on ramps and off ramps with the slow accel this has, and it hates hills. It is a lot smoother than my datsun though. I have several times found myself at 85 when I wasnt paying attention to the speedo! I am sure it could do more. I have read that the engine in these is 74 carbed, 90 with fuel injection. Is it a major pain to do fuel injection, and will it not pass smog? I dont think I see a cat on this so I am kinda wary of anything that might mess with my smog.
The fan stopped running on my old teg too. I wired up both fans to a switch after that and controlled it myself. That might get you into trouble at a smog station too, but I really have no idea.
Some cars are automaticaly sent to test only stations which are a bitch! They test to a higher standard and are very picky. What makes no sense is that my 86 honda and my previous 82 datsun both were models flagged as test only. My 77 ford E150 with a 4 barrel 351 windsor V8, not test only!
Miss that van. It certainly roared. And it could burn rubber.
