Son's "new" ride
Well here it is. My 86 wagon. Got it from a one owner, all major reciepts. Paid 800 for it. 113k miles. She just had a new battery, front end link bushings, rear brake hoses, wheel cylinders, shoes and pads installed for inspection. Figured I would start out fresh, today I installed a new timing belt, waterpump, crank n cam seals, tensioner, outer belts, full tune up, valve cover gasket set, adjusted valves, all fluids changed. I ordered a new fuel pump the outlet pipe is leaking where it goes into the pump and Im gona order a new valve cover cap. I cant handle that old rusted one. Over all a nice car. Once I get the interiour cleaned up I will post some more pictures. I think its going to be a good car for my son. The AC even works. I took my old 90 CRX SI rims and tires and put them on. The tires that came on the car were dry rotted in the tread and the steel rims were all rusted up.
Hopefully the pictures will come up. Im not real good with computers so we will see.
