Wagon 1/4 Mile Records
OK so post up your timeslips for 1/4 mile runs and i'll add them in below. Its not a record unless you have proof (i.e. a timeslip).
ALLMOTOR FWD
ogwagon's Civic Wagon LS 13.5 @ 101MPH
ALLMOTOR 4WD
FORCED INDUCTION FWD
honda>*'s Civic Wagon LS 12.1 @ 108MPH
FORCED INDUCTION 4WD
VIPwryann Civic Wagon RT4WD 12.4 @ 110MPH
http://www.youtube.com/watch?v=84Um-7TfwNk
ALLMOTOR FWD
ALLMOTOR 4WD
4wd
d16z6 single over head cam vtec swap fact rating 125 horse
aem cold air but.... stock dual point 1.5 exaust so it is even or worse i assume
im not sure where to shift i know it is higher than the stock redline i am shifting at around 7,100 i dont wanna hit red line and it is my beater so im not trying to kill it
also i did not shift it like a madman i am not comfortable grabing nasty gears like you do with the normal linkages those cables spook me plus i want to baby the trans and the drive train
with the stock exaust im sure large gains would be found at these high rpms with a larger motor i mean this is up about 40 horse from the dual point motor .....
i got in 3 runs
the first run i had just drove in and my car had bad heat soak my first time down a track launch low about 3,000 and soft bogged off the line car ran ok
rt. 630
60 2.600
1/4 17.769
mph 78.32
still heat soaked better launch about 4 grand then i missed 3rd
rt. 452
60 2.499
1/4 17.670
mph 76.18
i had my hood up let the motor cool abit and i launched real hard about 5,000 spinning the fronts a tiny bit off the line my shifts were not the quickest but precise
rt. .330
60 2.375
1/4 17.442
mph 78.65
i was racing at that point and i broke out i dialed in a 17.6 oh well ....
this is a full car no ac no power steering
trailer hitch random shit easily an extra 100 pounds so the verdict
i think with the exaust and get the extra shit outplus maybe some generakl love a 16.9 could be done maybe better depends on how you want to treat the ol girl
SOHC ZC, PG7 ECU
no muffler, no A/C
otherwise stock
Its been a while since i raced it but my best time was a 17.1 at 77mph i think. No time slip but heres a video:
http://www.youtube.com/watch?v=llNSgv_f6DU
My car comes out towards the middle.
88 RT4WD turbo
log mani
t3 42/48 turbo
380cc injectors
walbro pump
B&M FRP
100% stock d16a6 with 180+k miles
38mm WG
2 1/2 DP
act street performance clutch
blits BOV
obd1 conversion from rywire
p72 running crome pro
exhaust
I ran this with my alighment so out of whack that my was pushing the front tires so bad i could actually feel them slowing it down. since then i changed my inner tie rods and got a 4 wheel alighment and its a lot better now so i am positive next time i go that i will get a 13.??
A wagon is a wagon.
http://honda-tech.com/zerothread?id=1966318&page=3
Updated!
^^ will vouch. watched it run. watched it be built etc.
insane!
congrats!
wagovan FTW!
