Radio sound stops when honking the horn
I discovered last weekend that when I honk the horn, my radio stops. It doesn't turn off, just the sound stops. It's not a big deal and I don't really care about fixing but I wondered if this how the wagons were wired. My CRX didn't do this haha
If the radio can't find ground it will back feed through whatever circuit it can find. It may find it's way down a circuit related to the horn. When you honk your horn, the horn is using that ground and cutting your radio off. Unlikely, but possible. I've seen weirder stuff than that.
Are you asking me what ground is? Ground is the negative return path back to the battery. All the metal in your car is a ground.
Depends on which theory you subscribe to.
