Starter/Cranking Problem? Fidanza Flywheel on a 91 Civic RT4
I bought a used Fidanza flywheel that came off from a 92-95 civic. From what I told it would work on any 90+ Civic. Cable or Hydro. I also relocated my battery in the rear this time with a 4 gauge wire. Tried starting it & jumping it but all I can get is a "TACK TACK TACK" from the starter... as if the teeths aren't aligned up correctly to turn over & crank. Any thoughts?
I would look to the power cable and the grounds for your relocated battery. It sounds to me like you have a weak/bad connection somewhere that carries enough current to kick the starter solenoid, but not enough to crank the starter motor. If you remove the starter, take the time to swap the contacts inside the solenoid. They are the cause of 95% of starters needing rebuilt, the parts are about $5 at Autozone, and it takes about 20 minutes to change them.
