86 wagon suspension
what kind of lowering springs can i use i see everybody talk about the 88-91,but what about the 84-87? :?
    There's a thread here somewhere about 84-87 Wgn.Basically the integra DA engine /brakes bolt on to your wgn., But I 'm Not sure of the springs.I believe your fronts are torsion bars so can be lowered by repositioning the torsion bar.As far as the rear I've read else where that some1 used I think Acura cut springs(forgot what mdl).It was a mid-sized car.
  • capttrippcapttripp Band Wagon
    Any idea where that 84-87 thread is?
    I hear the best choice are coilovers.Some one told me of using cut DA integra springs(like the same trick clsmooth used on our gen4 Wgn ,except with less coils cut.
  • evol911evol911 familEE
    Re-index the front torsion bars and use Acura RSX springs in the rear cut to the height you want.
  • Ground control makes coilover packages for the 84-87 rears.
  • did some research the best way is to re index torsion bars cut the springs in the rear.use 87-89 integra rear shocks.the make no coilover kit for the 87 4wd.the 87 teggy front brakes will work if you have a donor car with everything. still trying to find a rear swaybar that clears the rear diff.you can use newer civic radiators.as i find new things i'll up date this page as i find things out.
