D16z6 valvetrain
Can anyone please tell me what these squirter things are? What I am talking about are the things on top of the cam bridge.
Also, I think my cam is badly worn, I tried to get pics but this is the best I could do.
Any ideas? I dont think I am getting oil to the top-end, I tried cranking the motor with the vc off and nothing happened. Thanks
Has this motor run before? Is this a fresh build? Is it a Vtec head on a non-Vtec block? If the later is the case, did you remove the oil control jet from the block deck before bolting on the head? If not, there's a pretty good restriction there for oil to the head. It should still get some though. Your oil galley below the cam looks empty. You may have a blockage. Is it possible the head gasket is on back to front?
