New RT owner with a few (car) issues. lots o' pics!
So I have a 90 RT4WD auto, got it in Feb. I bought it in Spokane, WA and drove it down to Boise, ID where I live. On that 500 mile trek, I had Zero problems. I went 80-85 most the way, up and down grades, wind snow rain etc..
So far so good...
So the next day I go snowboarding up at Bogus Basin (which is a 3200 vertical climb over 16 miles). The car is fine the whole way up, then on the way DOWN it starts overheating... The temp gauge was up then down then up etc.. so I coast it down the 16 mile mountain in neutral with the car off. I limp the car home with the gauge going from normal to hot every 2 minutes, but then instantly going back down to normal..
The next day I do the following repairs/maintenance- New T-stat, oil change (5w-30) and new filter, new air filter, new valve cover gasket (old one was leaking),new O2 sensor (CEL was on), drain and flush cooling system and refill/bleed.
I bleed the system according to the manual, fill it up, open bleed valve, keep filling until it bleeds a steady stream, turn car on, turn heater to hot, let system purge all bubbles etc and it all works fine for weeks.
Then I go to Bogus again and instantly on the way UP it starts doing the same thing- overheating with the temp gauge up then down etc.. I can only assume I have air bubbles trapped in there somewhere right??
So I bleed it again, and the car is fine for a few more weeks of in town driving.
Then, a few days ago I take a trip to Portland (which is close to 1000 miles roundtrip) and the car starts acting up again with the overheating. I am led at this point to believe its a more serious problem. My gas mileage went WAY down during this trip, and I burnt up a lot of oil too. Seems like the car has a hard time keeping cool when theres a load on the engine. I checked my fan, and it was working fine, so I know its not that. I did notice metal specks in the coolant- not quite sure if its left over Stop Leak or if theres a bigger problem internally....
A little history on the car- 2 owners, 262,000 miles, all original everything- engine/trans never been swapped or rebuilt -the car is pretty cherry though for its high miles. Interior is perfect, except for some cruddy carpet in the back, the paint is still good, and no rust in the usual spots.
Do you guys have any suggestions on what else I can do to keep my cooling system in check? Below are some pics of the car and some clarification pics too.. hopefully I can figure this out dammit! Thanks
Wagon with steelies, snow tires and yalkima rack......
Wagon now with Teggie rims and Falken Zeix 912s
Could this 'CACTUS' Rad cap be an issue?
Im using Prestone antifreeze mixed 50/50 with distilled water.
This is where my temp gauge normally sits....
Another shot of the car with steelies...
O2 sensor and Thermostat boxes, part #s etc
So far so good...
Also, have you checked for error codes on the ECU to see if a sensor or its wiring has failed? Could be a problem related to the coolant temp sensor under the distributor.
I would like to get a spare head so I can do a valve job and cam etc and have it all ready to go so I can just do a smooth head gasket job over the weekend.
Anyone know of a head for sale.. or better yet..what heads (if any) will work on the d16a6? Im looking for a straight bolt on, no frills, install...
thank you!
If I have to I will take the whole motor from ya- I can drive out that way if necessary. pm me with an asking price and hopefully I can work something out with ya.
on a side note... the stock cap should be rated for what pressure? 13psi or .9bar i believe is correct, which is what is on there currently. I did swipe two other caps outta the junk yard the other day along with 4 coolant temp sensors....just in case :P :P :P
I am only able to go THIS friday... if thats too short of notice its cool, but if it works out I definitely would like the whole motor. I'll PM ya an offer if you can get it to Baker friday
