And our roofs are wobbly enough as it is...you'd probably need to add some extra bracing up there. Doesn't one of the NJ dudes have a sunroof or two installed?
If you check out how the aftermarket sunroofs are installed you will find they have an aluminum frame that will reinforce the roof. I had one in my 84 Civic and liked it better than the factory one. The OEM Civic ones just slide into the roof. The aftermarket ones pop up and will vent much better with alot less wind noise. 8)
I was just thinking about a CRX one... However the CRX sunroof kind of sucked. They almost always rusted through and leaked, and they were only a sunroof when you opened it. Which meant for 8 months out of the year (in Canada) you couldn't even use them to get light into the car. I would rather swap in a newer sunroof, with a glass top and a interior sunshade. At least then it would make it worth my while...
Agreed.
Most of the CRX owners in my area have replaced their sunroofs with various blanks of some sort (be it CF, fibreglass or some type of tinted perspex)
Thanks for the info on the Hollandia sunroof's! They even have the CRX style one if you wanted it to look stock!
I think if I was going to drop the money on the install I would just go for the one that slides into the roof so that you can still use it if you had a bike rack on the car...
i have loose manual DA sunroof glass and no regulator or any thing i been playing with the idea of installing it on a wagon since 08 when i had my first wagon im trying to fab up an idea where it pops on and off like a T top with one of those lever locks hmm.
http://www.sunroofdoctor.com/popupkits.htm
I'd like to graft in the section from an Si...
needs a oillldriplet-ish ...
Love use every day...
I would certainly try...
would be a 1st...
lol
crappy pic no?
But what car is that sunroof out of???
That's a JDM Beagle, came with the factory moonroof
good luck.
sorry for picture quality
Eagle and Ragenasian:: what are the dimensions of your moonroof / sunroof? (glass area on the outside) please tell! thanks!
totally getting one of these now hah
And here goes the ridiculous question of the day "How much do you guys think it would cost to get a roof cut from a beagle and get it shipped?"
