Fuel Drain plug washer ? And PCV Valve ?
Anyone happen to know if the washer for the fuel drain plug on a 91 1.6 is a spechial washer of sort? Or will just any old 12 mm aluminum washer work.. Also does anyone happen to know where the PCV valve is located on the 1.6? I was looking around a bit tonight and didnt see it anywhere. Thanks for any help
The PCV valve is on top of the intake manifold, over on the driver's side. Look for the plastic gizmo with a right-angle fitting on top that connects to a gray or black hose.
Especially if you light it up with a blow torch till its red hot, it will swell back up even though it's been crushed before!
