Finding TDC on 1.5l wagon
Hi there. I just picked up a '86 RT4WD with a blown head gasket and am about to pull the head. I have aligned the TDC mark on the crankshaft pulley with the timing cover mark but am unsure about the camshaft pulley marks. There is no arrow or "up" indicated on my cam pulley. Only one of the two stamped lines (the slightly longer, less faint one) can be seen in the photo, but they are both sitting parallel to the top of the head. Is it at TDC now or do I have to rotate it another 360 degrees?
Thanks,
Luke
Thanks,
Luke
Thanks
If you have the crankshaft mark lined up, you ARE at TDC, the only question is whether you're on compression stroke or exhaust stroke. Are both intake and exhaust valves closed? (compression) Or is the exhaust valve(s) open? (exhaust stroke).
I suspect that you're at TDC, compression stroke. It just sounds like the marks are lined up from your description. BUT even if you're not, it wouldn't matter- as long as you put it back the same way you took it apart!
Do this before you take the belt off, just to ease your mind: Turn the crank a full turn, then see if any of the camshaft markings line up. I suspect they won't, and the exhaust will be open. Watch the valves as you continue turning the engine in its normal direction...you should see the intake open as the piston travels downward, then close as the piston comes up on compression stroke.
Then if you're changing to a new belt, just accurately transfer those marks onto the new belt, and line up your marks when you put it back together.
