Hello! i'm Doug from San Jose
Just picked up 1991 Civic Wagon White, i has a lien of sale but i have to get it registered tomorrow and smogged. Its got a cracked passengeer tail light, a few dents, crappy radio but working lights and front and rear wipers!
Oh, the fan isn't working i'm hoping its a fuse, any ideas?
Any help on why my window is hard to roll down and up?
You gotta give us more info, like pics and such...
so welcome Doug...
Down the line, when the engine is done, a swap!
Worn window regulators are a common problem and a pretty easy fix. Also check the window 'run' weatherstrip (the U-shaped one that the glass slides in) for wear at the front edge.
Fan- start by shorting the switch to see if it comes on. It's a big 2-wire thing screwed into the engine block by the oil filter.
The window kinda notches when goin up or down, rotating handle may need to be lubricated. Also the part that holds the driver side door open is loose, i should take the fender off and try to tighten it
