Adding power steering
So we just got Jen's wagon home and did a preliminary run through it. We want to re-install the ac that was removed, adjust the clutch(releses REALLY high, just replaced. ideas???) and add power steering. This will be her DD so PS is a plus. Shes a tough girl, But she IS little:) Is this a swap that we can get from any other PS equiped civic? sedan, hatchback, does it matter?
AND has anyone here done this?
Thanks in advance guys!
Dan
Dan
What I do when I want to check interchangeability is check on www.hondaautomotiveparts.com Just click you want to but it and then if you go to another car and see that the same part is highlighted red then it means its interchangeable.
But just about everything should change over except one main hose, but I could be wrong. I'm actually getting ready to de-power steering mine, but I will probably hold on to the parts for future use.
ohh... and something i forgot. the power steering rack is a little bigger around so the framing that the manual rack bolts into doesnt quite fit the power rack. i didnt realize this when i got everything from the junkyard so im gonna be going back. my friend that was helping me said we could just grind that part out but... i decided ill just get the right part.
