So my timing belt just melted in half
I was driving and all of a sudden their was a weirdo scraping noise coming from the engine bay and I was down on power. Good thing I was right by my house, I pulled up and popped the hood. I could tell that the timing belt was scraping on its cover, so I turned the car off right away and pulled the upper timing belt cover off. Much to my surprise, the timing belt had apparently started working it's way off and had melted/sheared off half its width on the cover. Whats left of the belt is actually holding tight at stock tension. It's dark out, so I'm going to wait till tomorrow to pull the lower cover off and see if I can figure out why this happened.
Has anyone ever had anything like this happen before? Any ideas what may cause this? The only thing I could think of would be the water pump or tensioner pulley starting to seize. Since whats left of the belt is still tight, I'm assuming the tensioner bolt didn't come loose. I was missing one screw, the only one that is in the middle area of the lower cover, but I can't imagine that could cause the belt to get demolished like this.
I'll get some pictures tomorrow. Thanks in advance!
Tom
Tom
I guess we'll know for sure tomorrow.
Apparently, the one timing belt cover bolt that came out somehow made its way inside the cover and lodged itself down by the crank pulley. Problem solved, crisis averted.
thanks for your help!
It wasn't the timing cover bolt. Good thing I made a little visual inspection before putting it all together.... TWO of the water pump bolts were missing! One got caught in the belt/cover and the other one is MIA. Good thing I had a spare water pump and bolts sitting around!
