Y8 into 88 DX
Hey everyone I'm new to the forum, I recently got an 88 DX wagon.
It was smoking pretty bad when I got it so I picked up a 97 D16Y8.
I am just staying DPFI for now just to get the car running.
I am doing some maintenance while I've got the motor out. Timing belt, water pump, clutch, gaskets...
I have run into a few problems, this is the first swap I've done solo.
1) thermostat switch harness plug. On the D15 DX motor it's on the back of the block and on the Y8 its on the back of the thermostat. Can I just cut the plug off any 96-00 civic harness and connect it to the DX harness?
2) alternator harness plugs. The DX harness does not plug into the Y8 alternator and the DX alternator belt doesn't fit the Y8 crank pulley. Can I depin the plug on 96-00 harness and repin it on the DX harness? are all the wires the same?
I have never done any kind of modification to an engine harness before so any advice would be awesome.
3) It looks like I might have to notch the lower timing belt cover to get the original D15 driver side motor mount to fit. I don't want to cut too much off and expose the timing belt to dirt etc. Anyone got away with no cutting the timing belt cover?
this photo shows the two alternators. The D15 one is mounted on the D16Y8.
Here is a link to an DPFI to MPFI
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
2 you can use the original dx alternator on the y8 and just use a 3 rib belt it will still work on the 4 rib crank pulley. maybe you could even swap the pulleys on the alternator.
3 yes youll have to trim at the timing belt cover to make the mount fit. no big deal.
im almost positive the stock dx dizzy wont bolt up to the y8. it will go on but the bolt tabs might not line up maybe one will. your best bet will be to go mpfi its really not that hard. and the y8 motor is a very good motor i would keep it if i was you.
Thanks for the advice. I would like to just use the 3 rib DX belt on the Y8 pulley but it's not long enough...I would prefer to swap the pulleys... Anyone know what size socket the pulley bolt is?
I test fitted the dx distributor and it seemed to line up fine. From what I have read, if you have a Z6 the DX distributor needs to be modified but it fits fine on the Y8 motor.
Thanks for the advice, I'll see if i cant find a EF ac compressor on craigslist. I will try to sell/trade some stuff to try to go MPFI as soon as I can.
The pressure plate is really hard to tighten down, there is a lot of resistance. I am afraid it's putting pressure on the flywheel dowel pins? I can't really tell if its rubbing on them.
Other than lubing the throw out bearing, what else am I supposed to lubricate?
This is a horrible photo but it shows where the dowel pins are, does this look correct?
thanks!
The pressure plate does line up as seen in the pics. The bolt holes line up %100 to the old pressure plate. As you can see I didn't tight it down, if I did it looks like it will put pressure on the dowels.
It came as a kit from http://clutchcityonline.com/ so if the flywheel is wrong I am scared the clutch is wrong also (It's the same size as the old one).
I hope you take this the right way. I really think you are in a little over your head. I think its great that you are taking on this project yourself but you should try to get somebody that knows this stuff to come over and give you a hand. Good luck and we will try to help you as much as possible but its hard to do online.
I would also have to suggest that you are in over your head and should get someone to help you or at least pick up a haynes manual from an autoparts store.
On the D15 DX motor, the fan switch plug is on the back of the block
On the Y8 motor it is at the back of the thermostat
I got a plug off a Y8 engine harness
If I solder the connections in this picture, I should be good right?
But I am having a great time learning, and it is always something I have wanted to do, so I am going for it.
http://hondatech.info/downloads/Auto/Manuals/Civic/
