I got a leak!
i just got this wagon a week ago and noticed there was a few dead wasp in the trunk area. so i started looking everywhere for wasp nest and found about six of them but one of them was behind the tail light so i go to take off the tail lite. i pull up the plastic pocket in the rear and find a good 4 inches of nasty water. where could it be leaking from? only thing i could think of is hatch seal or tail light? thing is it hasnt rained since ive owned it so it must have been there a while.
you might also want to check... www. hondapartsunlimited.com... they would have the gaskets..
LET THE SEALANT CURE FOR A FEW MINUTES, until it skins over just barely.
Install the light and run the 4 nuts up finger-tight while pressing the light into place with your other hand. After the silicone has fully cured, tighten the mounting nuts the rest of the way.
How to: make your own tail light gaskets
Nice quick and easy..
