Majestic Honda, good for parts and technical display
Are you trying to figure out what a certain part is in the rear area of your wagon? Are you lookin for schematics on a wagon, a civic, CR-V? How bout a price on parts. You can goto www.majestichonda.com for all of this.
Heres an example of what you can find there:
I already used this image to answer a question that another member asked about his rear differential. But can you imagine trying to explain some of these parts? I cannot. Not to mention what if you needed to buy a part? You can purchase what you see. Its that easy.
All you need to do is goto the link, goto parts, then plug in your year make, model, trim level, ect then BAM go right to your part.
At the same time you can research part numbers to see what is cross compatible between series.
Lets just say you want swap a CR-V rear end into a 4wd wagon? Can it be done? I dunno, but you can SEARCH IT!!!!
I've used www.hondapartsdeals.com as well with good luck and I'm definitely west of the Miss.
incl. shipping I got a rear qtr window $20 cheaper than my local stealer.
Thank you!
Tim
