Good Wheel Bearing Brands?
I'm looking at replacing the front bearings in my 2wd wagon. I know I will be fine if I use the OEM Toyo Seiko or Koyo Seiko bearings, but I was wondering about using Beck/Arnley bearings. $75.44 (OEM) versus $56.89. While I'm down there, the lower balljoints are getting replaced with Moog.
You're welcome to my press if you need it. I bought it and a bearing separator just to do my fronts, and haven't used it since.
I have a dinky little press that's not big enough, so I was going to go to this local shop and get them pressed. Since you have a press that would be awesome, I'll have to get directions to your place. I just know your in Marietta somewhere, so PM me with your address. I won't be able to work on it until about March 13.
Found koyo bearings: $81 shipped for 2 front bearings.
koyo i believed is the oe for most JDM cars. Timken is also a good brand since this company has been making bearings forever. kinda pricey though.
well at least you found what your looking for.
wagon.....................4ever....................
From what I've found with looking at EFs even ones at the local junkyard, the bearings are pretty durable, and usually something has to happen to the car for the bearings to die, its rare for them to take a crap just due to age. 188k on mine and kickin!
