Parts to increase gas mileage
As you all know, I am going to be purchasing a D15Z1 motor+tranny for the wagovan in hopes of pulling +50 mpg.
I wanted to know what aftermarket parts I could buy that would increase my mpg, or parts that would increase my power and not hurt my mpg.
I want to get as much gas mileage and power as I can.
These are the things I have in mind so far:
-light weight crank pulley with everything unneeded removed
-light weight cam gear
-header
-new 1 and 3/4 inch exhaust with a resignator
-maybe pulstar spark plugs
Is there anything wrong with these? Would you change any of them?
And what else would you recommend?
Thanks.
-header
Thanks.
And the most important - remove the lead from your foot - this is KEY. LOL
But I could be wrong.
And I'm aware of HX and VX rims, what other rims are lightweight?
DO NOT go over a 185 tire.
All the suggestions on your list will yield very small improvements.
Belly Pan:I'd focus on making a bellypan.Look under the current Prius,even the 2002+Civic HB.The next time you come up behind a Prius look at the rear tire fairing .The other choice would be a front spoiler,Accord side skirts(has a rear wheel fairing) ,removal of all the Wgn. mud flaps and the rear wing on my Wagon will help.
Exhaust:look at the OEM D15Z1 pipe size.I'm sure Honda optimized the size already.I think your 1.75" is too big.
One BIG prob you have is your 1991 Wagovan is around 2OO+ lbs heavier than a 88-89 WagoVan.
Alright. And thanks for your advice. I've never focused on mpg's before so this is completely different.
Also, does increasing airflow hurt your gas mileage?
And, do dyno's tune for gas mileage apps too?
Yes you can dyno for increase mpg.
Great to know. Thanks man for all of your help.
50 MPG highway? You'll want to reduce engine RPM (transmission swap) and reduce aerodynamic drag. Things like a front air dam, lower ride height, grill block (watch the temp gauge!!!) will help. Also remove one or both outside mirrors if legal in your state.
For city MPG, weight is the enemy. Gut it. :cool:
Try increasing the cam and ignition timing. Just don't let it ping.
I think a compression increase should help efficiency, but I wouldn't bother unless you have the engine apart for some other reason.
Tires inflated to the max pressure on the sidewall helps. I've been running 40 PSI on 35 PSI tires for many years, but can't officially recommend it.
I get about 38 MPG in a '91 Wagon. I've done the grill block. Air dam is coming. I'd love to swap in an HF 5th gear if I found one.
Check out http://ecomodder.com/ for a lot more info and some extreme mods.
Spark plugs can help. I reccomend NGK's Iridium plugs. NGK does make our OEM honda plugs. The iridium are the best they have and give the most consistent spark. Don't use those plugs with the 4 prong grounds, thats just a marketing gimmick, you want the leads to be smaller and let the burn travel more freely.
Another trick is to "index" the spark plugs. The idea is to point the opening gap of the plug toward the intake valves (use a mark or letter on the socket extension. This helps, but the difference is not measurable, however it is a free modification. Nets about 1hp on a thousand horsepower drag racer just to give ya a reference of how little it is in terms of power output.
The best thing is tires. and not just going with teeny ones and little ass wheels, brand makes a difference.
I have an EK. I have 16s that are not light, and I once ran 205/50/16 tires that netted 27mpg. I also ran 205/40/16 tires that netted 39mpg on the highway. Now the 205/50s were General and they were 7.5lbs heavier per tire and were also garbage. But the 205/40 were a Toyo Proxes. These toyos netted better grip (even a 205/50 Toyo that I ran), performance, AND fuel economy cause the tire compound was just BETTER. Granted they do cost more, tire composition can affect fuel economy by a significant bit.
A 205/50/16 Proxes4 is 21lbs, and a 205/50/16 Exclaim UHP is 25.5lbs . Thats 4.5lbs at the outermost diameter and 18lbs for the whole car, AND this heavy tire did not give as comfy as a ride. Its about 60$ a tire and the Proxes was about 90$ a tire. My point is tires are the single biggest aspect of fuel economy. Yes I know that the smaller diameter will throw off fuel calculation, but it also can reduce tire weight. Getting THE lightest wheels possible is one factor, but getting GOOD tires is a BIGGER factor for MPG than wheel weight by far, though the one that got better MPG being a little lighter was a nice benefit.
:shock: and
http://ecomodder.com/forum/fuel-economy ... ations.php
The Dunlop SP31 A/S are the cheaper of the two OE Hybrid tires.
Most of gas mileage increase is due to driver, not car. This is why the new Insight and Fusion Hybrid and the Prius all have interactive displays/games (they grow leaves and change colors depending how you drive) to help 'coach' drivers to be more economical in HOW they drive.
Read about Hyper-Mile-ing
I agree!! I used to get ~35 mpg with my D15, and now I have a D16A6. The engine feels so much better, that I want to rev it higher all the time, and so I've been getting like 20 mpg (also fried the wire on my O2 sensor). If you don't ever go over 4k rpms you will save A LOT of gas! How I drive has definitely made the biggest difference in MPG in my wagon.
http://www.partstrain.com/store/?Ntt=to ... src=search
this thing cant work!
They don't, i have one that was bought for me as a present and it seemed to due nothing.
Too much to go into now, but some investigation of hypermiling is in order. Most of the ideas in this thread are good, but investigate.
I used the clutch to push-start the engine so I didn't overheat the starter motor. I regularly achieved 49 MPG, with my best run averaging 54 MPG.
While mods will help -- especially the tires and the belly pan -- aero doesn't have much affect below 45. The biggest difference is how you drive it. Accelerate slowly, stay in the highest gear possible, keep the engine revs low, keep as light a load on the engine as possible.
Thanks for all of your help. I will do all of that hopefully. I got 440 miles on my tank not to long ago.
Thats with an HF motor and Wago 5 speed tranny.
great information about coasting and things. I appreciate it. I will try that.
