*SOLVED*Temp Gauge Problem
A while back my temp gauge kept quickly shooting up to Hot and then back to its normal position. It would do this roughly every 5 minutes. I replaced the sending unit and this didn't help. I also checked the resistance of the wire from the sending unit to the gauge and made sure there weren't any cuts in the harness. I got a new gauge which seemed to fix it; I haven't had a problem in about a year.
The other day it shoot up to Hot again and went back in about 2 seconds. I noticed back before I replaced the gauge it would mess up more after I have driven the car for a while, which how it happened this time. The circuit is very simple, so the only thing that can cause this is a short to ground somewhere along the sending unit wire. I'm guessing inside the harness (probably in the engine bay) this wire's insulation has been rubbed off making it intermittently short. So far it has only done it once, but I'm curious if anyone else has had similar problems with their temp gauge.
It seems weird that replacing the gauge fixed my jumping needle earlier, so I'm wondering if the gauge is going bad again :evil: . It seems if the wiring was to blame replacing the gauge wouldn't solve anything. If two gauges are exhibiting the same jumping behavior, I would guess other people would have had the same problem? I don't know:
Bad wiring or... Bad gauge
I have several spares of all that stuff. I guess you're down at school, but you're welcome to come by the house and swap parts to your heart's content when you come home...or I'll try to send you what you need, just let me know.
Thanks for the part offer, but I'll probably just keep an eye on it for now. At least its only done it once so far. Yeah, I'm down at school, so working on it in the dorm parking probably isn't the best idea. Although, I've had to before, but that was to get it running again. I'll let you know if I end up needing some part.
