Tow Hitch - just built this at my buddies house thurs/fri
Well, guys I finally got around to building my custom tow hitch. It turned out even better than I thought it would. The little tow ring on the back was in the way so we just cut it off and replaced it with a 11x5x3/16" plate with 4x 1" grade 8 bolts. We also made a 7x5x3/16" plate with the same 4 holes drilled and bolted it to the other plate that was welded in the car. Now we centered the receiver tube and cut it down to the right length. The 2 tie down brackets on each side of the car also hold the hitch. Each side has 3x 14mm bolts. I'm hoping to pull a 8x6' flat bed trailer with 2 quads on it. I'm hoping to keep everything under 1500lbs. We'll see how I do. I'll be testing the hitch in 2 weeks. I'm going up to my dads, he has a 400lb aluminum trailer and we're going to load up 2 of his quads on it and see if the wagon and pull it decent. If so I'll build my trailer big enough to hold 2 quads. I also have a wiring diagram to convert the lights on the wagon to standard trailer wiring (took me 2 hours to figure out the wiring and draw the wiring diagram). I'll post it here for you guys as well. Here are some pictures of the hitch.
i went to one of the local welding shops and they said it would be like $400-500 (est.) to get a class 2 receiver made to fit the wagon. i hope it hauls like you want it to.
1.25" Receiver tube - $25
Steel tubing and plates - ~$40
Safety Chain Ring - $5
3x relays for wiring - ~$6
14ga wire - ~$5
Hammer Texture Black paint - $7
Grade 8 Bolts - ~$10
4 wire trailer connector - ~$7
Total price - ~$105
Smile on my face after completed and how sick it looks - Priceless
Great work... on the hitch...!!!!!!
what other welding modifications do you have in for the wagon.... :?:
I have a few wild ideas under my hat.....
but
*I want a swing off tire rack ( stock RT wheel with a 27x9.50R14LT SSR Series of Super Swamper Radial/TSL ) rear modified bumper so I have a full size spare with me always...
*a winch on the front with a functional modified bumper/ bull bar or brush guard... ( not made of chrome plated aluminum )
*a safari basket on top is a must... I have a set of awesome JCB lights that have 1-H3 bulb, 1-H7 bulb, 1- small parking light bulb, 1- amber turn signal ( HID KITS all the way... )
Project Scrappy Doo is gonna B a fun one....
just might have to buy a tow hitch from you
im interested in buying a welder but am unsure of what to get to make tow hitches and other load bearing devices.
Thanks for that update!!
