ZC DOHC for an 89 RT4WD any benefit to different years
I've found a few ZC DOHC motors to swap into my 89 RT4WD and was wondering if there was any benefit to getting an 88-91 version vs a 92-95 version. The two motors I'm looking at right now are
88-91
92-95
I'm open to getting a motor from pretty much anywhere but that place is the closest with the best price I've found so I can just go pick the engine up rather than paying shipping.
From what I've read elsewhere it seems like either of these should just bolt up but the later model might need an adapter for the ecu? The items are listed as including the ecu so does that still hold true.
This is gonna be my first motor swap so I'm trying to get everything as close to fitting right off as possibly to reduce a little bit of the pain down the road. Thanks all.
88-91
92-95
Watch how many beers you drink before you do this. I know this was my biggest problem lol
Other than that it's pretty straight forward.
In addition I've been trying to search but does anyone know of any good write ups that cover the whole process. This being my first swap any guides/tips or info can really help. Is there anything particular to the RT4WD that I might miss from reading non RT4WD stuff.
Depending on where you buy your motor, it will come with the Japanese harness. We just de-pinned the stock dizzy plugs from the A6 harness, and re-pinned them with the Japanese dizzy plug. One had two plugs, the other has one plug. Can't remember which had which. Easy and not janky. But you could splice if you're ok with that sort of thing. Solder it and do it right if you do. Don't use butt connectors.
But ya, make sure you buy an 88-91. That will be the only wiring you need to do.
Please search!!!! I know I've already posted this info so many times on this forum....
http://www.thezcr.com/
It's just like lego, get the bits and go nuts you can't mess it up, easiest swap in the world.
That's the one I used!
We actually did this. Except all of the bolt mounting holes don't line up. I think 2/3 if I remember right.
This is the distributor adapter you will want to get. I have no idea who this guy is but he is awesome.
Save your money and re-pin it yourself
^ x2!!!!!! Thats the one you need. Thanks Skyler, I couldn't find it on EBAY when I was looking for it.
Did you not get a JDM harness with your ZC? Seems like a waste of 15 bucks to me
That's what I like to hear. Though do I need to modify my lego's a bit? I was reading on an old thread of yours that the zc exhaust manifold won't fit. I gotta use the one from my old motor and grind the ports to match. Is that right?
Also do I need to pull the transmission with the motor or can I leave it in the car and just pull the engine by itself? Everything I've read thus far has been for FWD and tells you to take it all as one unit. If I do need to pull the transmission is there more steps other than pulling the front drive shafts that are necessary since it's an RT4WD transmission?
Thanks again for the help. A good community of people who know what there doing can really help to take some of the headache out of this stuff..
Use the top half of the DOHC ZC header and the bottom half of the SOHC ZC header, they will bolt together fine, clear the ports fine and also clear the transfer case and sump.
I would remove the engine and transmission as one unit in this case. If you were changing only the gearbox then i'd leave the engine in the bay, but to change the engine with the gearbox still in there would be incredibly awkward. In fact nearly impossible becaause of the crank pulley.
why you just start...
shoot a lot of pics...
some of you/US like that...
I know I do...
:shock:
No. The HEAD from the DOHC ZC will not fit on the SOHC ZC.
Use the top half of the DOHC ZC exhaust HEADER and the bottom half of the SOHC ZC exhaust HEADER.
so it wont work? but whats the difference w/ the dohc zc top header and sohc zc header?
lol
Any ideas where to pickup just the sohc zc exhaust to get the lower half? Should the importer I'm getting the engine from have them? I couldn't find much on ebay.
You cannot use the full DOHC ZC manifold on the RT4WD. It does not clear the sump and transfer case where the two pipes collect into one.
I didn't see it was a 4WD. I guess I have to read better. :oops:
I didn't see...
hey...!
I'm begging for pictures here...
:shock:
jeezzz
the humiliation...
and my knee hurts..
