Stereo question
has anybody on here ever installed a capacitor in their audio system.
how do you hook one up.......im totally clue less on these things.
if anybody can help that would be great.
just so you know its a 0.5 farad cap made by monster
cable, i bought it on ebay. they said it was never used
thanks
thanks
positive post -> positive of the system
negative post -> negative of the system or chassis ground
There are other ways, but this is the method i've always used.
dont they can do some serious damage
Edit: you'll probably want to use the supplied resistor and UN charge it if you take it out of the car... those things pack quite a jolt if you accidentally touch both the terms
Oh, and one more thing... DON'T put it in while the car is running :P, i always pull the main system fuse as well, to make sure there's no current while i'm putting it in line.
haha yup
kelowna eh... I'll be up there in May for knox and the peachland car show.
bringing the wagon in the avatar?
that should be easy to spot lol
hope too.. just starting the turbo B swap.. should be ready for may long
you' gonna need an extra battery...
with an .5 Farad you top is about 500W RMS
hook it up straight to your battery
with fuses off course using the thickest wire possible...
about 25-35mm2 based on .5 Farad
and replace alternator with higher capacity...
thats about it...
however...
usually upgrade battery and alternator...
should do fine up to 1 KiloWatt...
without capacitor...
