NEED SOME TROUBLE SHOOTING HELP
Hey guys, I just picked up an 89 wagon, it had a frozen alternator and cracked radiator. I fixed the alternator and changed out the radiator, hoses and thermostat. I did a compression check (all good) and bled that radiator according to Chilton manual. Checked the fan and it is working properly.
The problem I am having is it will sometimes run very hot to the point of overheating. I only notice it when the car is going up an incline or driving on the freeway over 55mph. When I am on the freeway, it doesn't start overheating for a good 30 miles, when I notice that the temp gauge started to rapidly rise I started to pull over, but noticed that when I was less than 55mph the temp goes down. So I drove it farther, it didn't start going up again till about 5 miles from my house. I did the same thing, I put it on neutral and coasted for about 1/8th mile, then the temp went down. I finally get off the freeway and went through stop and go traffic, and the temp never went up.
So I was wondering if anyone can suggest a reason for this, a solution or something I can do to fix it.
Thanks for all your inputs!
1. headgasket (compression check was good though)
2. waterpump
3. thermostat (changed)
4. S.O.L.
just a thought.
I tested it with a 9volt battery, and also it kicks in when the cars at idle.
I installed the thermostat correctly. I have a feeling the water pump is going out or head gasket.
It could only be so many things but my luck it is always the last thing that fixes it. You could always jack the car up so that the radiator is the highest part of the motor. However the little bleeder valve worked good for me too. If you are going to put a new water pump on it don't skimp out and only do the water pump. It will save you headache later.
after the engine is stone cold, open the bleeder valve, remove radiator cap, fill to full in radiator and check overflow tank, fill to full mark. run engine for a minute or two to distribute fluid. check level again in radiator and fill till the bleeder overflows (as sumodesigns said) close the bleeder valve first then fill to full in radiator.
check the overflow tank level and run it on the freeway for twenty/thirty minutes. check the levels, add as needed, if at all.
if I've mis-stated any of this somebody fix me, it's been a while since I did this.
...jm.
Took it in to my honda mechanic friend, he did some test, and found that there were a couple of issues.
1. There are oil droplets in the radiator, leaking headgasket.
2. Flow pressure through the radiator when under a load is very low, water pump. Also if you listen very carefully to my engine on the waterpump side u can here it (bad news).
He says, if I am changing out the motor he recommends to just change the waterpump for now and since the headgasket is only leaking ever so slightly, he just said to watch the oil level.
Hopefully this will help others out.
