Front Window Tracks Replacements
Hello Everyone
My driver's side and passenger side window tracks are shot to the point where i can put my windows up and down with my hand, are these hard to find? Are they interchangeable with other Honda's? if so does anyone have a diagram of them or maybe a parts manual showing these parts? thank you for the help.
Regards,
Deathseeker31
Regards,
Deathseeker31
*I did a little bit more research in regards to these parts and The parts I need would be the actuators and the window guides, now that i know the actuators are Wago specific, would the guides be wago specific also? Wouldn't we be able to use sedan guides? If anyone has any more input i would greatly appreciate it.
Do a search under ,Window Crank Problem or syringe(strange ,but works).
This will help a lot & buy u time to find a parts.I recommend doing this procedure before the crank wears out too.
Also read the thread on a member that did power window conversion using sdn. parts.That may help.It was a pretty new thread.
