how to fit a CRV upper wing onto your wagon
Step 1:open boot
step 2: remove trim, just squeeze your fingers under and pull down and the trim will pop off
Step 3: There are 2 bolts/screws holding the high stop light on, unplug the wiring. Slide the high stop light towards the window glass and it will come loose.
Step 4: there are 3 10mm bolts holding the trim on, one in the center and the other 2 are in the holes at the edge. Remove the bolts (carefully as they like to escape into the cavity where you cant reach them) and shut the boot. Pull the plastic trim towards you and it should slide off.
Step 5: Line the crv wing up with the plastic trim. the crv wing has 3 bolt holes in it, one in each side will line up with the edge of the wagon trim and drill a hole. note: you will need to use bolts with a small head, the normal hex head bolts sit too tall and the trim will not fit back on.
Refitting is the opposite of taking it apart.
Step 6: stand back and admire your work
All you need is some fiberglass & filler to fill the gaps and your done.
