EDM cluster?
I'm assuming this came from a french car because, of the french writing on it, the person I bought it from on ebay said it was JDM but it obviously isn't, can anyone throw in some input on what type of cluster this is, thanx!
  • Pics won't open up :roll: ...Either way it looks like its Canadian more than likely judging by the 200 KPH max readout. You'll know for sure if you see MPH in smaller numbers towards the inside of the gauge.
  • yep, damnit! would you know any info on how to install?
  • Looks like an 88-89, correct? Should plug right in and work...if not, swap the tach/speedo assemblies into your old cluster. Just make sure they are the same both either Nippon Denso or Nippon Seiki brand...
  • NengchangNengchang New Wagonist
    Yeah it should plug right up. Good luck.
    that is Canadian son... not JDM or EDM.
  • My led upgrade
