Tranny issues - EDIT: NEW INFO
After solving my starting issues, a new one has risen.
When downshifting from all gears, I can hear a whirring sound, especially when the clutch pedal is pressed down. Also, I've been having a harder time getting into gear, mostly 1st thru 3rd. I'm hoping a tranny fluid change and tightening of the clutch cable will fix this. I know Honda MTF is highly recommended but is gear oil okay for now? Has anyone ever had this whirring issue before and if so, what did you do to fix it? Thanks in advance!
Don't use 10w30 motor oil or gear oil as this causes rough shifting.This recommendation was made by Honda 2O+ years ago before the New Honda MTF(w/additives to make it smoother shifting).
Also, a new starting issue has come up. The last issue was resolved with a new dizzy cap. I'd go to start the engine, and I would just get fast clicking. The battery voltage is at 14.4-ish when the car is on and 13.5 ish when off. I'm pretty sure it should be at 12 ish right? Is my battery in need of replacement? Or perhaps it needs to be filled with distilled water? I've read that here somewhere but not sure if that is the reason I'm getting the fast clicking... Anyways, I'm off to search for these symptoms here on HCW. Thanks again!
As far as the shifting problem is concerned, did you inspect the pedal assembly bracket for cracks? Did the shifting feel any better after the adjustment or exactly the same? Try adjusting it more and see if there is any change.
If it feels somewhat better, then the problem lies with the engagement/disengagement of the clutch and probably not the transmission. Most likely the clutch disc is worn/damaged, the pedal assembly is cracked and not allowing full travel of the clutch fork, or the clutch cable is worn/stretched. I have also seen this problem caused by very low oil level in the transmission. If after checking these items and changing the transmission oil you continue to have issues,
you will have to drop the transmission and inspect and/or replace the clutch and associated bearings and go from there.
Now going back to your starting issue. If you suspect a bad battery, you can take it to most auto parts stores and have them test it free of charge. First check all of your grounds. Pay particular attention to the main chassis ground going from the transmission to the body right under the battery tray area and then to the battery negative terminal. If it's dirty/rusty anywhere it makes contact, clean it with a wire brush or sand paper to ensure good contact. If its corroded (green), replace it. Try that first. Then check the electrical connections at the starter motor solenoid. There should be one heavy gauge wire and a thin gauge black/white wire. Make sure these are securely attached and free or corosion. If that doesn't work try whacking the starter solenoid with a long extension and hammer. If you find that after whacking the starter solenoid the car starts, then replace your starter motor assembly. The solenoid sits right above the starter motor and is a cylinder shape that is roughly 1/4 the size of the motor itself. It is attached to the starter motor and comes complete with a new starter if you replace it. I hope this info helps. Good luck.
ogwagon, thanks for the info! It's truly appreciated! I will be doing the tranny oil change tommorow morning as I have some free time finally. I will be using 10W30 as I didn't have a chance to pass by a Honda dealer to get some Honda MTF. I will also look at the pedal assembly and the starter solenoid as well. Battery too! Again, thanks for the info and I will defintely update tomorrow evening.
Tried adjusting the cable and it seems better. Going to try to adjust it a bit more but I've noticed it seems like I won't have anymore adjustability as the knob is coming close to the end of the threaded piece. FYI, I pulled this cable from a junkyard wagon so maybe it is already stretched past the point of adjustments? We couldn't find a new cable anywhere at the time.
I looked up at the pedal assembly and I didn't notice any cracks and wgen pressing on the clutch pedal with my hand, didn't see the pedal move side to side at all. The pivot looked good as well with very little movement.
As far as I can tell without looking at the previous owner's receipts, I think it still may be the original clutch. If the problem persists I may take it in to a local shop and hzve thrm look into it.
Thoughts?
I've also seen this sort of starter behaviour from a loose battery terminal. Give them a good firm wiggle. If they move at all, they're too loose, and this is likely what's causing the starter issues.
I use to use 10w-30 oil too.It felt fine to me until one day I drove my friends Civic .It shifted smoother.He told me his Acura mechanic put in Honda MTF.
As I said earlier Honda does mention using 10w-30 oil,BUT that shop manual is 2O years old.NOW Honda shop manuals say use Honda MTF.
Honda quote:
HONDA MTF FTW!
I've used a CRX Si Cable for all my B-series swaps in my Crxes... should be the same as the wagon...
Darren, the clutch cable currently being used as well as the spare one I have are from an ef and an ee although I can't remember which is which.
ogwagon, could my clutch issue be revolving around the clutch release arm (I'm not remembering the proper name here) not completely releasing the clutch?
The car shifts okay from 1st, 2nd and 3rd if I shift between 2500-3000 rpms. Anything above that and it's harder to shift out of or get into 1st, 2nd or 3rd.
Man...
:shock:
and you couldn't find a ef cable out there.. that sucks
the shifting sounds like synchro trouble to me, does it grind at all?
Unless the cable is wrong or bad .Peeps doesn't it sound like a worn clutch :?: .
definitely sounds like it, however you won't be 100% sure until you crack the bell housing... so we've been trying to eliminate other issues until there's nothing left... to try to avoid separation...
Darren and SiWagon, I'm hoping to eliminate everything I can before I have to drop the tranny and inspect the clutch. I will try my spare cable and maybe even buying a new cable as well as switching to Honda MTF. Thanks again for the help guys!
try palls pushing the wagon...
you/anyone steering and shifting...
that must tell some tales...
a hill (down : )would be nice...
no engine running...
I agree... if you've tried everything else, it's all that's left
Thanks for all the advice guys! Now I know why I'm on this site all the time!!
He's right.
