When to Shift Gears
I have been driving manual trannys for 20 years now (damn I'm get'n old). I prefer them over automatics, not only because Im a control freak but I think they also keep me more awake and alert. Occasionally I'll have a bit of a friendly argument with another control control freak passenger (that would rather he/she be in the driver's seat) about when is the "correct" moment/RPM to shift to a higher or lower gear while accelerating or decelerating. By "correct", I mean the most friendly on the overall health of the engine.
I've had my Wagon since only this past summer and..being that there is a small hole in the muffler (AKA noise), I've been contemplating my RPM and shifting.
General question is for you all...What do you think is the best cruising RPM for your wagon at each gear? When do you shift? Do you downshift or just brake to slow? I'd love to hear how you fuel/engine minded wagon owners move through the gears.
Some drivers run it high..say 3000RPM before shifting. I am on the low side...about 2500RPM. Does anyone think I'm lugging the engine too hard?
Other(most :oops: ) times I shift at 7000. Soon I will make that 8500.
The speeds shown are the maximum at
which the car can be driven or downshifted
in each gear without over-revving the engine.
1st 53km/h (33mph)
2nd 88km/h (55mph)
3rd 132km/h (82mph)
(On the 4WD)
SL 32km/h (20mph)
1st 45km/h (28mph)
2nd 75km/h (47mph)
3rd 116km/h (72mph)
Recommended Shift Speeds
For best fuel economy, and effective emission
control, shift at the speeds shown...
1st - 2nd 24km/h (15mph)
2nd - 3rd 43km/h (27mph)
3rd - 4th 62km/h (39mph)
4th - 5th above 86km/h (53mph)
quote page 72
viewtopic.php?f=16&t=7804
ah....gotta love on base gas stations in other countries.
when I was stationed in Korea, it was around $2.30 per liter outside. PER LITER!!!
back on topic: good info Eagle Beagle.
Based on the above, 40MPH would be 4th gear and you wouldn't shift into 5th until 53MPH.
ABOVE 85km/h (53mph) 4th - 5th
I think it got something to do with common...
...sense or knowledge...
there is the table/chart
4-5th rule/line accompanied with the word
ABOVE that makes all the difference
Honda safety-rules...
at that point you will be
reaching 100km/h to 60mph-ish
and 5 is OVERDRIVE...
hope everbody is familiar with the meaning of overdrive...
so yeah... i dont know...
good point...
you'r right, you allllright you
HOWTO:Make the muffler last way longer
I use to be with everyone about shifting when the engine tells you,but found out I was hearing the wrong voice.My shifts are done at 2,000rpm most of the times.I'll shift higher for hills or heavier loads(cargo or mo passengers).You'll be surprised that it does not lug the engine.I've been using this technique for a few years now.My gas mileage went up 1O%.I learned this from a hypermiler,but they do it while depressing the gas pedal 80% down ,which does lug the motor.
But the thought of running in 3rd as far as 82mph makes me cringe, Ive seen too many teenagers in tricked out Hondas around here trailing blue smoke.
Next muffler, I'll definately will do the drill thing, thanks
How can u shift so fast that must be slow. Well now u know when to shift.
Have fun and now drive like a pro lol.
~20 mph. sucks, but its been done lol
why is it begging for problems though?
no knock whatever with that extra tap... because, uhm... its you ?!!
Whoo! That's gonna get some mixed responses. Take it easy on the new guy
Also, it sounds like it's not the drivetrain (more like engine/muffler) but in 4wd if I shift too low (like 2-3 at 20mph) and I accelerate a bit the car makes some sounds and rattle (in the rear), when I'm in 2wd (with the switch on the tranny) it's smoother at low rpm. If I don't accelerae, I put my 5th around 40mph. I used to drive a 1.0 geo metro, my civic feels like it has a lot of torque now.
But I think these cars are reliable, I don't rev it high so often but I don't think it's really bad, especially on 88-91.
is it about economy or...
maximum accelaration ...
example:
maybe a shift at torque or rpm how-to explanation..
in a new topic...
it's a calculation based on many elements to complete the set...
1st @ around a 1000rpm+
2nd @ 1700 rpm+
3rd @ 2000 rpm+
4th @ 2100 rpm+
5th @ 2400 rpm.+
