Rusted rear bumper support? Make your own!
Just thought I'd update you guys. After not being able to source a rust free bumper support, I built a rear bumper support bracket similar to the ones that are used on the JDM/EDM pictured below (thanks for the pic, Marc). I'm kind of bummed because I accidentally deleted the pictures I had that showed the finished product. I used an L bar from an old bed frame, but really any metal stock should do...the L bar allows for a bit more rigidity than say flat stock. Any rate, it was free which made me happy. All I did was then measure it to the bumper and then measure the holes on the body for where to weld on the legs and bolt holes, cut, grind, re-measure, weld, grind, attach.
At any rate, it's on the car now and I put some weight on it and it's sturdy...surprising being my first welding project. The only thing I would do differently is use black oxidized flat head bolts to attached the support to the bumper skin at the top so the fasteners aren't as noticeable. I would have also welded on the bolts in the lower holes, and a nut on the top hole (on the bracket) as trying to fit your hand up underneath the bumper while it's on to fasten it down was a pain, also cut me up a bit.
Anyway, I'm happy with my cheap alternative. Wish I wouldn't have deleted the finished pics and measured everything at the end to provide here as well. :oops: Here's some pics to give you an idea...
What I wanted it to resemble when done: EDM/JDM Rear Bumper Support Bracket
www.civicwagon.com
What I was working with...
Start with L bar, mock up, measure, cut, re-measure...
To get it to concave with the bumper... (x is where you want to wack it :lol: )
I then sprayed it with some paint to protect it somewhat from the elements and further rusting.
Accidentally deleted pics of the final product. :x
Underneath...
On the car...
Not bad for close to free!
And yes, that's snow on the roof! :lol:
  • sometimesidosometimesido New Wagonist
    nice!, I need to learn how to weld from my roommate.
    Good on ya, dub! That's my kind of solution.
    Heck yea nice work!! Im having trouble trying to find a good one for my crx i may just do this!!
  • uhm...rust prevention...
    any ???
    :shock:
  • Thanks guys, I hope it helps someone out. I know this is a common problem.
    This was kind of my learning project. :lol:
    any ???
    :shock:
    Yeah I used some, but unfortunately deleted the finished pics. :( You can see it on the underneath shots though.
    Just curious why you didn't use a rubberized rust preventative?
    Pretty neat though. I would have done it different had I not seen this thread, but now that I have I will/would do the same thing for shaping it!!
  • a rubberized rust preventative?
    good point...
    i think its an example of replacing...
    not how to protect for the next 20 years
    thats his next chapter...
    :mrgreen:
  • good point...
    :mrgreen:
    Yup, it was a cheap/free first attempt. I would do things differently next time, and if/when this one rusts in a couple years or so, I'll make a better one.
  • QCnukQCnuk Wagonist
    Thanks for the ideas -- better than the two straps I am using!
    (Yes I've got snow -- had at least 4 feet already)
