The Desert Wagon
Now that I know I won't be junking / parting out / selling the wagon, I thought I'd make a build thread. This is going to be pretty straight forward; no turbos or engine swaps, or even headers for that matter.
I really just want to add some style to the wagon, and fix up all the little issues (like door dings and window regulators).
So here is a quick run through of the work I had to do to get the car to a reliable DD status:
Bought the car with blown valve cover gasket and head gasket
Found the Water Pump to be pretty disgusting
Replaced Everything I could once the head was off
Milled the head to remove damage from previous owner
Powder Coated the Valve Cover
And Cleaned her up.
So far it's been a great little DD, and now I have a couple things lined up for style points!
I've got a Yakima roof rack that I'm picking up today, and some Koni Yellows with the Skunk 2 Coilover kit on the way!
Here is my concept for the car, still trying to narrow down rims, offset, and stance...
And Cleaned her up.
check it out.. DRAGINMYWAGON...
makes it special...
and more happening too...
maaaaaaaaaaaaaaaaaaybe...
I am still not sure about the rims. And I have some ideas on how to accent the car with the battleship grey color.
We;ll see how it turns out...
I got the roof rack, now I just need the visor!
welcome.
Some more of the rack...
As you can see, these are actually the wrong towers. I got them to work, but they are for raingutters....
Looks good dude.
Yeah! Nice.
The rack does make a lot of noise with out the faring.
I am gonna keep the RT wheels. I've already had a offer or two, but I think i may keep em, then have them dished and powder coated.
Before I moved, I took the wagon to Show Low to get some winter snow action. The car did well in the snow, and on the road trip until I was about 30 miles from my destination.
Suddenly, the water temp gauge started going down, then the battery light came on. The car was driving rough and losing power.
I pulled over at a gas station and found that the main pulley bolt had come off completely. The pulley was wobbling around and the alternator belt was missing.
It turned into quite the adventure. I got the car towed, the shop told me that the car needed a new crankshaft!! I told them to put down the joint and got a ride back to Phoenix. I had to leave the car in Show Low for a week. .The next weekend, I rented a car dolly and went to get her.
check out the pics from the trip:
And here is the old and new pulley:
Here you can see the damage to the key. My guess is that the pulley/harmonic balancer was out of balance, and having it wobble so much during the road trip cause the bolt to back out.
I got a new pulley, bolt and key from Honda. It was an easy install. Car is running well now, but just in case, I check the bolt everyday!
5 panel wink mirror!
Just installed tonight, better pics later.
It amazes me how much crap was just slapped together when they put in the ZC! I mean, I understand wanting to get her back on the road, but I mean, knocking this stuff out is way easier when the engine is out!
Got a nice little present from OldSkoolEf! today! Time for a little drop
Before
After
Before
After
Here in kingman, were up by lake havasu.
You Welcome, Enjoy!
I have 185/70s too
By the time I got it going, the allen head was beginning to strip out. So I had to drill the allen head out with a power drill. I knew the shock was pretty much trash at this point, but I wanted to salvage the top hat.
I ordered just one shock from O'Riely's but it won't be here until Tuesday, so the car is sitting on jacks stands until then...
I have a feeling the rears are going to be dropped pretty significantly... look how much space there is between the top hat and spring still!
