replacing piston rings
hi there,
so, i have this 90 rt4wd with a stick. ~ 112k miles. i've had it since the spring, but have only really put on any miles since the weather turned here in new york (about 3 weeks). anyway, it seems to use a fair amount of oil, maybe 1 qt./400 miles or so. i replaced the valve stem seals in the fall to take care of a problem with them, so i figure it needs new rings. not sure what the compression is like, but it seems to run fairly well, so i don't think that's an issue.
my question is this. i read on some forum somewhere about a guy claiming to have changed the rings on his car ( a toyota) without pulling the head off- he was able to do the whole thing through the underside.
i've never heard of this (not that that means anything...)
has anyone here had any experience with changing the rings, and does the above (do it without pulling the head) seem possible? it seems like it would certainly simplify the process.
I've built scores of engines,from Briggs and Stratton to Cummins, and can't recall even one that this would work on. Why would you not want to remove the head?
any other thoughts?
thanks again.......
do you have smoke? Is your coolant or oil milky or froth like?
I would highly recommend a compression test (you can rent them from an auto parts store for free).
second, a bunch of reading convinced me to have a look at the pcv valve. there is a lot out there that suggests that a clogged pcv will have a negative effect on oil consumption. a new valve from napa was $11, and 10 minutes to find the old one (which was plugged) and install. i'm hoping that this will help with the oil consumption (111000 miles seems a bit early to need new rings). we'll see. it can't hurt, and may save me a big (and maybe unneeded) tear down this spring.
i'm pretty good about tracking the mpg as well as the oil consumption. i'll do another post in a few days time to let you know if these things have had any effect (i put a lot of miles on this car, about 80-100/day, so i should have some idea soon).
lol
Save yourself the headache, and just swap another long block.
Questions are awesome. But building a motor isn't something that should be done by asking IMHO
'If you have to ask...'
good luck
that is...
you need the right tools,
skill, experience, knowledge...
etc, etc, blah blah blah...
but never hurts to start...
somewhere...
still, i'm waiting on a few tanks worth of gas to see what effects, if any, the pcv valve and smoother intake have had. no sense doing a job this complex if the gains won't justify the effort.
in response to an earlier post, the coolant looks fine, no evidence there of a blown head gasket.
someones lawnmower...
needs an engine...
and having faith...
repair equals knowledge...
i'm not you...
would like to help...
but can't...
sorry
