auto to manual
hey , im a new member to this forum and i recently got myself a rt 4wd wagon 1990. one big problem i got was that it is an automatic and i been searching for a manual 6sp but had no luck on the price that i want to spend. so i went and settled for a auto. where can i find a manual transmission? anyone you know that is selling a working transmission? i also own a 1988 mr2 supercharged and needed a DD and bought myself a wagon. hope this forum is like the mr2 forum that is helpful
- tranny
-clutch, flywheel (flywheel mt bolts, and pressure plate bolts)
-rear tranny mount that bolts to crosmember or can cut leg off and move over
-rear stamped tranny mount that bolts to tranny
-shifter cables and shifter assembly
-passenger side tranny mount that bolts to tranny and the 1 welded to frame. or you can modify the 1 that is on frame
-pedal assembly
-clutch cable
i believe thats it. i just completed the swap on my 91 rt. its alot of work but my auto tranny went out and had been planning on doing the swap for 2 yrs. good luck on finding a tranny. when you do make sure u get all the bits to go with it. i parted out a 5 speed awd thats how i got mine. any questions u can pm me i also have pics of my mount modified if u want to see.
A-Team...???
...no???
good question...
great answer...
Once you have introduced yourself with a post in the New User Introductions sub-forum, you will be automatically added to The Marketplace Group once you have made five valid posts within the general forum.
If you look under your screen name it says you only have three posts.
