Cruise control
Has anyone installed an aftermarket cruise control on a wagon?
I'm going on a road trip in August and plan on giving my right foot a rest while I drive... :twisted:
Cheers !!
Cheers !!
I'd say search google for some info
http://brandsplace.stores.yahoo.net/0002-ccs100.html
I found this...it lists several Hondas. Might be a better, albeit more expensive option, but I can't speak from personal experience:
http://www.mnrelectronics.com/roscruiscon.html
http://www.the12volt.com/installbay/forum_posts.asp?TID=75172&PN=1
Honda cruise control:
talk about multi-functional parts!
...jm.
"The only way the cruise will work on the Wagon(&all Civics) is if you use a ECU with cruise(it's built into the ECU)"
Does this mean that if I *wanted* to put a new ECU in, I could put one in that was new enough to include CC? If so, what else (if anything) would I need to have to make CC work?
Thanks,
Jenny
I could ask him what brand name he uses and if there are any precautions to observe. Will keep you guys posted.
Jenny
:oops: Evidently I found out that a CC out of a '90-'91 Civic Sdn LX(orEX)(other '88-'91/'96 Civic's w/CC may also work) will work in our Wgn.You'll need all CC related pieces out of the donor car.........& the Gas,Brake & Clutch Pedal assembly(too) to make it work.The guy that did it took a day to extract the CC & 3 more days to install it.
:? :oops: I think it's the AT Civic's that has it built-in into the ECU from '88-'89.
http://causeforalarm.thecarthing.com/cr ... index.html
