Any trick to the tranny filler bolt?
I HATE the damn transmission filler bolts on most ever Honda I've owned. Either they've been over-torqued by previous owners/shops, or they just seize easily, but most of the times I can't get it out, end up stripping it.
I want to change the fluid in my transmission, but having bad experience in the past, I always try for the 17mm filler bolt first. Sprayed with PB blaster the day before, let it soak. Gave it a go with an open ended wrench. Nada. Torch. Nada. Got some 'Freeze off' stuff. Nada. Even tried grabbing onto it with a big pipe wrench. Now it's fairly stripped and the thing still won't budge.
ANY advice? I can't imagine how old that fluid is in there...
p.s. The rear diff went without a hitch and it was the first I've ever tried. Something with the filler bolts on these old trannies. :x
:idea: Maybe try this.Drive on the highway for a while.Maybe this will heat up the casing enough to loosen it .Even better wait till a hot Summer day to do it.
:arrow: Shop manual does say to drain at operating temp.
I really feel like a dumbass for being the only one with this problem, but I've seen it on a couple of these and didn't think I was the only one. Oh well...
Only one problem with that method: how do you know when it is filled to the proper level? I've filled thru the VSS several times, but had the fill plug out to determine amount.
You could remove the right axle
my buddy filled his GSR trans that way but overfilled badly. The breather had like a steam coming out and it shifted funky.
Bam-Bam has the right idea. If that is your last resort then do it up, pull that axle and the VSS. Just make sure the vehicle is level when filling.
Good luck bud
:idea: Do you have a buddy at the tire place? This is a very common tool for a tire guy to own. They use them to remove locking lugnuts when they don't have the key. Maybe you could borrow one? Or just come on by and borrow mine!
aka thermodynamics...
anyway...
work that thing...
good luck...
be carefull...
I'll just have to get under there again.....after it's nice and hot...and get at it. Thanks for the insight guys.
Another option is to measure how much fluid you put in, but that would be too easy
Thanks for the ideas guys - felt like a total noob.
and it worked. Good luck
