Headlight switch
91 RT4WD. If I have my headlights on and use the right turn signal my headlights turn off. New switch right? Well I ordered one off Ebay, hope its good. Now, when installing the new switch do I need to remove the steering wheel, or can I simply remove the steering column cover?
literally takes less then 1 minute.
here is how to do it:
with a fine flat head screw driver (or something similar) carefully pop out the "H" in the steering wheel.
behind that there is a 19mm bolt. take it off. steering wheel will now slide off.
voila
EFs get jealous and cranky.
