help me get rid of shifter play
so when my car is in gear i can move the shifter left and right about a half inch in each direction what causes that? is it a worn out bushing or something else?
i guess my real question is would a short shifter or some sort of new busing get rid of that play and if they dont make them for the wagon are ef or any other civic compatible? i also plan to throw on a weighted shift knob for a better feel
We may as well make this the definative shifter thread because when i searched about it there are alot of topics on it but nothing solid.
What i can add:
-EE/EY/EF FWD Wagons use the same shift linkage setup as the 4th gen hatch/crx
-EE/EY/EF RT4WD Wagons use a cable operated shift linkage similar to the H-series Prelude
-Both setups apprently use bushings to limit slop or play in the shifter
And also something from a post by turbo_teg:
Anyway, I looked at a 2G Integra shifter next to a wagon one, and the wagon stick was longer below the pivot ball by maybe 1/4". I didn't have a hatch or sedan shifter to compare, but my theory is this: Since the EE shifter is longer-handled (for higher operator position relative to the floor) the bottom part was made longer to compensate for the noodly feel you get from a long lever. Make sense?
This is just a theory, I could be wrong. And it does nothing for you if you want a short shifter for your wagon, but cut the handle down and you've got a low-buck short-throw for your sedan/hatch/crx.
sorry about that, its a 1989 civic wagovan 5 speed. ive been trying to bring this civic up to date and this was a problem i wanted to fix. if you guys give me some ideas on how to get rid of it i have no problems being a guienna pig for this experiment ill post pics.
EDIT ill try to find a place to buy bushings for the wagon an ill let you know if it helps
