Any 84-87 Wagons running d16a1?
Just curious if it bolts right up to the block or not. I know you can run a d16a1 tranny on the Crx/Civic Si Ews and vice versa, you can run Crx/Civic Si tranny on the d16a1 block.
So will the d16a1 bolt up to the Civic Awd? I know it runs a carburetor, but I know the everything involved in converting it to Fuel Injection (i know firsthand!!!! Not fun).
You have to cut the top bolt hole of the rear T bracket off.
