I want to changed I see a 92-95 or 96-00 civic d15b non vtec that motor is the same as my o I have to do a lot of modification o and the auto trany mount to that motor ok
"I need to swap my engine. It looks to me that a 92-92 or 96-00 Civic D15B non-VTEC engine is the same as my old motor. Do i have to do a lot of modification? I have an auto tranny, will the mounts from my motor work with those other ones?"
someone answer this guys question
my short answer..
YES, you can use those engines with your stock motor mounts. i would recommend the 92-95. however the wiring is different and you will either have to do a MPFI OBD-1 conversion for the 92-95, or you may use your stock wiring if you use your stock intake manifold, header and distributor (not sure if this bolts directly to the 92-92 motor though).
you should never be bothered on HCW...
insane in the membrane...
I`m here to may friends and the same time learn about wagonvan ....I don`t just the people!!!!!!! Here because I love wagons like everybody else here.... sorry for the inconvinient....
not happy???
viewtopic.php?f=5&t=7369&p=80304#p80304
this thin g?
somebody was
my short answer..
yeah, i'm sorry too
