disconnecting shift linkage connection?
this is in regards of a 2WD DX 5-speed Wagon...
how do you disconnect the shift linkage arm from its connection at the transmission? same for the second arm, whatever that is.. so basically, the two arms going into the tranny?
seems like there is a pin of sorts, but i have no idea how to get it out of there.
There is a saying, "for any job you can use a hammer, if that doesnt work get a bigger one, if that doesnt work then the problem is electrical"
ROFL!!
yea the bitch pin has its name for a reason. and i would also recommend using a bolt to replace it. so you dont gotta deal with it again
http://www.performanceforum.com/wesvann ... bitch.html
It is all about technique & a BIG HAMMER w/a some #@%^ %#@ *%^$ %$#%
GL
The other bar should just have a bolt holding it to the bracket, and a couple bolts holding that bracket to the tranny.
thanks for all the input, guys
the c-clamp method looks good and causes less possible damage if any vs using a hammer.
I removed the bitch pin by using a very long extension bar connected to a socket holding a center punch. I lined it up from under the hood then used a BFH to hammer it out. I also placed a jackstand up against the shift rod for support. it took a while but it came out. then applied some anti-sieze to the new pin before installing it.
You, or whoever next has to removed the linkages will cry with happiness because of that
Good stuff
thanks for all the input guys!! really helped A LOT.
never heard these two in the same sentence before! ha lol
It has shifter cables. No bitch pins to worry about!
Using just a bolt will not put constant pressure on the connection like the roll pin did and you will eventually develop slop in the connection.
