hasport axles..help
Okay well i have a b16 in my car but i need to buy bseires axles but i dont know if i buy hasport axles for an ef if it would fit my wagon even though its for an ef. Do we have the same same size hole in the hub? please help
Yes, the hub/spline on wagons is the same as other 4th gen. Civics. In general, any swap parts will interchange between hatch, sedan, crx, wagon. So, if you get axles to put that swap in an"EF", then yes they will work.
But...I also have a '91 sedan with a B16, and I seem to remember the guy who did the swap telling me something was different about the intermediate shaft. Like he had to get an LS halfshaft to run LS axles because he cuoldn't find the B16 axles? I'm not real clear on that, maybe this'll jog someone else's memory.
On my car with a B18 swap, I used the axles from my '92 Integra donor car.
As I said early most honda/acura outer hubs are the same - there are a couple exceptions - I believe the 88-91 CRX HF has different outer hubs - that's the only one I can think of that is different off the top of my head right now.
There are also two different styles of trannys on the B series. The cable trannys have different intermediate shafts and different sized output shaft seals than the Hydro B series trannys. Just make sure you match up the right intermediate shaft and axles to the right tranny. Rule of thumb - 90-93 Integra = Cable tranny, axles and intermediate shaft - 94+ integra = hydro tranny, axles and intermediate shaft.
Will the axles that Hasport sells for a Bswap into an "EF" fit a wagon as well? (yes)
