The u-joint situation is a sad one. Honda never produced a replacement and to save money in production they used a pressed in u-joint as opposed to a conventional one. It's a terrible idea on their part. I just dropped my read prop-shaft yesterday because of a terrible joint issue as well. For now, drop your drivehaft so you won't cause anymore issues to your drivetrain and hopefully an option will come about. I may have found a fix for the u-joint issue and as soon as I know I will be making a thread about it. A local shop to me says they may be able to replace them. Otherwise I know someone on the boards here replaced theirs with a Ford Ranger u-joint after some modification to the mounts of the shaft.
