Throttle control cable adjustment, rough shifting
I've been having problems adjusting my throttle control cable on my 91 rt4wd automatic. I have been adjusting it at the top by the firewall and intake manifold and when I do it either idles too high or still shifts a little rough at times. Should I start adjusting it at the throttle control lever near the tranny first and work my way up? and how much free-play should there be? Also the backing nut up at the top keeps coming loose, is it ok to use thread-lock there or is there a better way to keep it in place? And when I adjust the throttle cable too tightly and idles high, it shifts very smoothly, so im pretty sure that this is the cause of my rough shifting.
Sounds like you need a manual for a step-by-step on how to adjust.
Someone needs to make a writeup on adjusting the idle and throttle cable!
