New Wago guy northern ca
Hey guys i just found a link to this sight on a fit forum. im so stoked i thought i might be the only wierdo into wagovans out here.
THE CAR
i bought it for 100 bucks with a blown headgasket.
im currently gathering parts to install my k20z3 but shits so expensive
so here its current specs
91 civic wagovan 2wd
clean title
166,xxx miles on chassis
15k on motor
99 b20b bottom end
95 Gsr head
arp headstuds
stock cams
stock bottom end
cometic .031 head gasket
all new valvetrain harware from honda
new vtec oil rails
golden eagle -6 an vtec oil feed kit
-6 stainless fuel lines with inline fuel filter
vortec gsr supercharger kit 4.5 psi pulley non intercooled
hondata s300 in usdm p30 ecu
dc 4-1 header heatwrapped
p72 timing belt and water pump
vortech fmu
RC 550s
new oem radiator and hoses
rebuilt s1 Sir transmission, close ratio 4.4 final drive oem lsd
act street strip clutch
fidanza 7.5 lb flywheel
tokico illuminas 5 way adjustable
skunk2 coilover 8k 10k
rhino front camber kit
spc rear camber kit
integra DA front knuckles with new calipers pads and rotors
konig helium 15x7 with 205/50/15 falken azenis
hasport mounts
custom shift linkage
slim 10' fan
all obd1
front of car has been seam wlded, wire tucked, and brakeline tucked. the motor mounts have been boxed as well
gsr guage cluster with electronic vss
gsr shift knob
now with the pics
THE CAR
clean title
15k on motor
99 b20b bottom end
95 Gsr head
arp headstuds
stock cams
stock bottom end
new vtec oil rails
vortech fmu
RC 550s
spc rear camber kit
hasport mounts
slim 10' fan
all obd1
gsr shift knob
now with the pics
WOW, I'd be happy with the B20/Vtec with the supercharger, going "K" huh.
its a 2008 civic si motor with 11,000 miles on it.i know the chick who wrecked it and got it for a steal
i was wondering if anyone has fitted the sir frontend onto a wago?
if so i sure would like to see
i have the hood and headlights.
i know the lights will fitt but i havent tried to fit the hood
any insight would be much appreciated
NJCIVICWAGON1: viewtopic.php?f=5&t=165
SoCal-Wago: viewtopic.php?f=5&t=6500
