1986 Wagovan 1500-d16a6 swap??
whats up my fellow wagovaners?? yes i know this is my very first post on this site. but i am no noob to hondas. soo i bought a 1986 honda wagovan it is the 1500 series and a rod bearing went on it. simple fix. but the 1500 series is also carbuerated (sp??) i also have a d16a6 in my 91 civic hatch and i was thinkin about swappin it into my wagovan. so my question is will my d16a6 line up with the tranny on my 1500?? it is a 5speed with a SL gear when 4wd is engaged so technically a 6spd i know im obviously gonna have to swap my wiring harness and ecu in place as well. but will i have to modify the rear mount and the drivers side mount as well?? or will it be a direct swap in??
thanks for the help
thanks for the help
HTH
You can use a browntop/blacktop D16A1, will bolt up to wagovan transmission if you chop off the top bolt location of the rear T bracket.
no thank ya i live in minnesota!
alright thanks! ill check that out!
